L. Caldwell
#1 Posted : Thursday, June 10, 2010 9:12:22 PM(UTC)
L. Caldwell
We have a Maytag front load stacker washer, 2400A model. We were getting the "nd" error code. Took out the drain and there was a nickel in it. Put it all back together and now we get a humming noise whenever we try to run any cycle. No error code. Any suggestions? Is there a way to reset the computer on this? Thanks!
richappy
#2 Posted : Saturday, June 12, 2010 2:47:42 AM(UTC)
richappy
I would check all connectors inside, perhaps one came loose. Also, check the pump impeller, it might be busted from hitting the nickel.
