I have an Amana dryer that is not shutting off when using the electronic dry cycle. It works fine when using the timer, though. Any thoughts on this?
THIS FORUM IS DEAD!!!!!!! |
ok, I tried testing the sensor by putting a piece of metal across the sensor and I started the automatic normal cycle, it sounded the beeper 3 times to indicate self-test which is normal, then removed the metal piece after a few minutes, and it worked fine. This has been an intermittent problem, though, when doing the laundry, sometimes it works fine and sometimes it never shuts off.
Intermittent problem is a synonym for tech's nightmare as every time you try to repair it the unit will run OK. Here is a bulletin on the moisture control board that may apply http://www.servicematters.com/maytag_library/docs/ASQ-234-B.pdfOften an intermittent problem is a bad solder joint or connection but in this case that should stop the dryer before the clothes are dry not keep it running. I would check the connections from the moisture sensor to the board to ensure there is no dust etc. between them. Check the solder side of the moisture control board for bad solder joints. Often a cold solder joint will be a duller gray color. It may have pin holes in it. When gently wiggling the componen you can see it's leg move on the solder side of the board.t After that I would replace the moisture sensor board but this is just a guess and I hate doing Plug & Chug repairs. Keep plugging in new parts till the unit chugs along on it's merry way. |
