porgas
#1 Posted : Sunday, June 21, 2009 7:23:40 PM(UTC)
porgas
I have a Frigidaire Laundry Center with the front load washer. It recently threw the belt. I put the belt back on and it worked fine for a few months. Two weeks ago it threw the belt, I put it back on, the next time it came off the belt was shredded. I replaced the belt. It will not stay on the drive pulley. Almost immediately upon starting the washer the belt comes off. I have put it back on numerous times and it continues to come off. The drive pulley seems to have a lot of play in it and it appears to have cut into the back of the washer tub. The model number I listed is the model number on the inside of the dryer door. It is the only model number I have found anywhere on this laundry center, and I have looked everywhere.
richappy
#2 Posted : Monday, June 22, 2009 2:50:37 AM(UTC)
richappy
You probably have bad tub bearings. Turn the spin basket and see if you hear/feal bad bearings. Post results.
porgas
#3 Posted : Monday, June 22, 2009 8:03:41 AM(UTC)
porgas
I spun the basket and I hear absolutely no noise with the exception of hearing the drive pulley rub against the back of the tub. The tub spins freely. Any suggestions are appreciated.
richappy
#4 Posted : Monday, June 22, 2009 2:41:24 PM(UTC)
richappy
You still probably have bad bearings. You might want to repost as a bearing problem.
