JohnM
#1 Posted : Tuesday, August 7, 2007 10:55:22 AM(UTC)
JohnM
Last wash produced a loud graunching noise ... if there is such a thing!! Finished the wash fine. Today, ran it empty ... with a cleaner in. Hot water is left in it. Has the pump failed? If so, is it easy to fix?
#2 Posted : Friday, August 10, 2007 8:27:45 PM(UTC)
You have been a member since:: 7/19/2007(UTC)
JohnM
What kind of cleaner did you use? What is the complete model number of your dishwasher? You can find it on the right side on the door.
JohnM
#3 Posted : Friday, August 10, 2007 8:47:53 PM(UTC)
JohnM
Problem now sorted thanks. Managed to get pump out form the bottom of the machine. (Odd bayonnet fitting) Could find nothing wrong with it ... nor could I find any glass ... but in the process of working on the machine it could have moved on! Reassembled ... now the embarassment ... assuming I had achieved nothing, got a repair guy in who found it faultless and it's still working fine. Good guy as he charged a nominal fee.
This seems to be a common problem ... acknowledged in that the motor apparently reverses up hitting a foul up. They are quite easy to remove.
apart from learning this, found e-fix supplied part at fraction of Bosch. Found a call out from Bosch would have required me to remorgage my house!
loadster
#4 Posted : Monday, August 13, 2007 11:13:22 AM(UTC)
loadster
I just replaced my drain pump and if I didn't have the new part in hand, that 1/4 turn bayonet latch with plastic keeper would have made me pull the base from the tank. The sprocket impeller drain motor still rotated but had a bad spot on the bearing. If yours 'graunched' once I would expect it to happen again. I'd buy a new motor if I were you. Otherwise, expect to be bailing when its least convenient for you.
vlibruce
#5 Posted : Sunday, August 26, 2007 10:25:06 AM(UTC)
vlibruce
How Do I Get Drain Pump Out Of Bottom Of Dishwasher I Have Everthing Acsessable But Can Not Figure Out How To Get At The Pump
#6 Posted : Monday, August 27, 2007 12:30:06 PM(UTC)
Hi vlibruce
The reply posted by loadster has very good solution for you.
Good luck.
loadster
#7 Posted : Tuesday, September 4, 2007 7:06:11 AM(UTC)
loadster
on the bosch 43XX series, getting to the drain pump for extraction means taking off the front face panel and the 90 degree bent steel panel(unpainted) at the door hinge. It may also involve removing the left vertical side panel. (power disconnected)Then find the electrical terminals on the pump and with a pair of needlenose or hemostats, depress the keepers on the contacts and pull the slide terms off the spade contacts. The pump removes by depressing the white plastic keeper lock located at about 2:00 on the circumference of the pump housing where it inserts into the tank sump and turning the pump counter-clockwise 1/4 turn. Then with the dexterity of a small monkey, you can extract the pump from the tank/catchbasin prison. On the new pump, use silicone grease on the o-ring and reverse the procedure. There's alot of sneaky keepers on these parts, I'm guessing Bosch really didn't want the owners to do this.
Sorry if this is too late to help...
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Bosch Dishwasher Model SHE3AR56UC/07 (Dishwasher Repair)
by EDK1747 8/30/2023 7:42:58 AM(UTC)
Bosch Dishwasher SHE3AR56UC/07 (Dishwasher Repair)
by Guest 8/27/2023 11:27:21 AM(UTC)
Bosch Dishwasher skips to "clean" even after part replacement (Dishwasher Repair)
by Guest 6/20/2023 5:17:19 PM(UTC)
Bosch dishwasher SHX65T55UC/07 not dispensing soap unless in "Express" mode (Dishwasher Repair)
by callussun 4/19/2023 9:46:00 PM(UTC)
Bosch dishwasher shem3ay 55n/25 (Dishwasher Repair)
by Guest 3/23/2023 5:18:20 AM(UTC)
Bosch dishwasher only drains on reset and specific cycle (Dishwasher Repair)
by vusedad 10/18/2022 8:54:46 AM(UTC)
Bosch dishwasher model SMV41D10EU/48 Not working (Dishwasher Repair)
by adriandlb 10/7/2022 12:18:47 AM(UTC)
Bosch Dishwasher SHX68T55UC/02 Leak Identified: How to Fix? (Dishwasher Repair)
by jonneytaee 8/31/2022 4:48:51 AM(UTC)
Bosch Dishwasher Model SHPM65Z56N (Dishwasher Repair)
by Guest 7/8/2022 9:00:03 AM(UTC)
