sheila
#1 Posted : Thursday, December 27, 2007 5:04:58 PM(UTC)
sheila
Washed 3 loads then washer stopped dead , after 10 hours of rest it began to work fine...still working, have only done 2 loads consequetively since. What is going wrong. Dont want to wait for it to completely die before fixing or knowing what to fix.
misterfixall
#2 Posted : Thursday, December 27, 2007 6:06:09 PM(UTC)
misterfixall
there is not enough info yet, keep using till more definite signs
richappy
#3 Posted : Friday, December 28, 2007 1:35:43 AM(UTC)
richappy
Bad idea! Measure the motor current with an amprobe before you burn out the motor! Should be around 8-9 amps. Above that and the motor will overheat. Motor overheating verified if it will not re-start after turning off. You can pull the outer cabinet off and check if motor is very hot.
Guest (6)
