alord
#1 Posted : Friday, June 19, 2009 5:38:53 PM(UTC)
alord
I have a Whirlpool microwave that shuts off after 3 secs of operation. I spent several days looking on the net and found several posts specifying replacement of the magnetron. Well, I just replaced the magnetron and it is still shutting off after 3 secs. Anyone have any ideas? I am now $60 into a new magnetron and it didnt fix it so now I really kind of feel obligated to fix it......
Thanks in advance!
sly33
#2 Posted : Tuesday, September 1, 2009 11:52:05 AM(UTC)
sly33
I am having a similar problem along with an F2 error message, I was informed by 2 different sources to change my touchpad.
SublimeMasterJW
#3 Posted : Tuesday, September 1, 2009 12:17:23 PM(UTC)
SublimeMasterJW
The fuse is good because it will run so the door switchs are ok because it will run so It must be a part that clears the way for the high power to kick in. I could not see a triac on the parts list but I did see a thermister.
http://www.abt.com/images/produ..._Files/gmh5184_parts.pdf
What if the thermister is shorted and the brain of this space shuttle cannot get a heat reading inside the oven? That part is 20 bucks and a lot of them are crappy. Try to find out what the resistance is supposed to be of the thermister and see what that one is reading. That is what I would do.
