jas1000
#1 Posted : Thursday, December 27, 2007 11:21:09 AM(UTC)
jas1000
Does anyone know if the bake element on a Frigidaire Gallery range can be replaced from inside the oven? The bake element won't heat, but the broiler element and the cooktop elements are fine. The control panel also seems normal. When I set the oven, the temp display is normal and the "oven" and "preheat" lights come on - but the bake element remains cold. I assume it needs to be replaced. Thanks!
#2 Posted : Thursday, December 27, 2007 11:49:31 AM(UTC)
Yes, the bake element is accessible from the front.
Remove the power from the range, remove the screw on each side of the bake element and carefully pull it out without forcing the wires.
Check for burned out wires.
Remove one of the wires from the bake element and check continuity on the bake element.
Replace if it's open.
If there is nothing wrong with the wires and the bake element, then replace the control board.
- The part number for the bake element is AP3776837
- The part number for the control board is AP3854311
- The part number for the control board overlay is AP3776841
Good luck.
jas1000
#3 Posted : Thursday, December 27, 2007 12:04:43 PM(UTC)
jas1000
Thanks Gene!
billvh
#4 Posted : Thursday, December 27, 2007 1:54:55 PM(UTC)
billvh
WE HAVE MODEL #RF367PXDN is the part # we need AP3075035
billvh
#5 Posted : Thursday, December 27, 2007 2:03:46 PM(UTC)
billvh
GE oven bake element (Oven Repair (including Ranges and Cooktops))
by 72yrsoldwoman 10/27/2023 6:22:03 PM(UTC)
Whirlpool oven bake element doesn't come on (Oven Repair (including Ranges and Cooktops))
by Gotzman 1/16/2016 8:41:52 AM(UTC)
ge oven bake element will not turn off (Oven Repair (including Ranges and Cooktops))
by rgaden 8/20/2014 9:51:39 AM(UTC)
Kenmore Elite Oven bake element not heating (Oven Repair (including Ranges and Cooktops))
by ADN140 12/16/2013 12:24:26 PM(UTC)
Oven bake element works sometimes (Oven Repair (including Ranges and Cooktops))
by tallshouse 3/4/2013 7:05:10 AM(UTC)
Oven Bake Element (Oven Repair (including Ranges and Cooktops))
by JMAL 4/25/2012 8:47:14 AM(UTC)
oven bake element required (Oven Repair (including Ranges and Cooktops))
by Olga-C 4/20/2012 10:04:16 AM(UTC)
Attempting to install a oven bake element (Oven Repair (including Ranges and Cooktops))
by livelifeest1973 3/9/2012 12:36:51 PM(UTC)
by carguy50 2/23/2012 1:55:12 PM(UTC)
by Dolores814 1/13/2012 10:36:05 AM(UTC)
GE oven bake element not working, broil works. (Oven Repair (including Ranges and Cooktops))
by HelpMeAnyone 12/25/2011 3:39:09 PM(UTC)
Oven bake element lead (Oven Repair (including Ranges and Cooktops))
by Ctwild 12/5/2011 4:33:39 AM(UTC)
Oven Bake element not working (Oven Repair (including Ranges and Cooktops))
by NickJade 11/14/2011 8:17:42 AM(UTC)
Oven bake element does not heat (Oven Repair (including Ranges and Cooktops))
by crna1 7/5/2011 11:18:31 AM(UTC)
Magic Chef oven bake element (Oven Repair (including Ranges and Cooktops))
by Rafat 6/29/2011 11:42:53 AM(UTC)
