my light under the built in microwave doesn't work -ried to replace bulb that isn't it -he wire also turns the turntable and that works fine any suggestions?
Remove the bottom panel, disconnect the wire harness plug to the lights and check for 120 VAC to the surface lights while the control calls for lights. If there is no proper voltage then the control board has to be replaced. - The part number for the control board is AP3892569Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1170XSY0 | AppliancePartsPros.comGene.
