I recently moved my washer and now it jumps araound and vibrates during the spin cycle. We have made sure that it is level all the way around and it still does the same thing. We have taken it a part and all the springs are there.
Even if you believe the washer is leveled properly I would double check its installation in accordance with the Installation instructions. Make sure the floor is solid. Gene.
The washer is level according to the instructions and it still does the same thing. There are plastic feet on the bottom of the tub that we are unsure of where the are to sit. Is there some where or way that we can get a diagram of this or is there a way that I can send you a picture of them?
