The oven will not work, baking or broiling. What can I do to fix the problem.
Thank You.
The display is normal, nothing out of the ordinary.
I can only think that there could either be a problem in the main electronic control or in the unit's spark module. There doesn't look to be any fuses, etc. which could account for your symptom. The main control tells the spark module to open the gas valve and to spark the burners. A problem in either might account for your symptom. JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
