Mazz
#1 Posted : Sunday, June 14, 2009 7:38:30 PM(UTC)
Mazz
I have a Kenmore Trash Compactor that has a problem with the motor overheating. The odor is "ozone" like, and there is some smoke visible. The motor will stop mid-stroke, and will not continue until cooling down for several minutes.
The unit will sometimes complete a full cycle, but begins to vibrate and shake, on the up stroke, which makes the drawer pop open. I think it may be time for some lubrication. I'm wondering, however, since the motor has obviously overheated several times, if it should be replaced. Also, what other issues should I check? The unit is made by Whirlpool, and I've ordered a service manual for it.
#2 Posted : Monday, June 15, 2009 5:25:24 PM(UTC)
The first thing I would do is lubricate the power nuts and the power screws (#12 & #2 on the diagram). The part number for the grease is AP3134980
The motor troubleshooting is described in the tech sheets.
- The part number for the motor is AP3081024
Whirlpool Gas Dryer motor overheating - shuts-off (Dryer Repair)
by animateme 9/19/2019 11:59:22 AM(UTC)
KA washer motor overheating (Washer Repair)
by dalack 6/20/2015 7:33:31 AM(UTC)
Motor Overheating (Washer Repair)
by dmett41691 5/17/2014 6:38:27 PM(UTC)
GE motor overheating (Washer Repair)
by BrynDN 9/22/2009 6:28:11 PM(UTC)
Motor overheating (Washer Repair)
by gejettest 4/23/2009 11:55:00 AM(UTC)
