Ian
#1 Posted : Tuesday, December 25, 2007 7:00:27 PM(UTC)
Ian
The oven is not working on this unit. The broiler and range burners do work. I don't know if it is the igniter or the safety valve or the thermostat. What is the logical way to figure out which is to blame?
Thanks,
Ian
#2 Posted : Tuesday, December 25, 2007 8:42:38 PM(UTC)
Hi Ian
The first thing I would do is check if 120V is coming to the bake igniter when the thermostat is calling for heat.
If there is 120V then the bake igniter has to be replaced.
If there is no 120V, check continuity across the gas safety valve terminals.
If it's open then the gas safety valve has to be replaced.
If there is continuity, then the oven thermostat has to be replaced.
- The part number for the bake igniter is AP2592343
The gas safety valve and the oven thermostat are no longer available.
Good luck.
Ian
#3 Posted : Wednesday, December 26, 2007 4:44:08 AM(UTC)
Ian
So, I'm kind of a rookie here. Can you elaborate the procedures for any of the above suggestions. I was wondering also, even if it is the igniter, is it worth it to fix this unit, since it sounds like other parts are not manufactured anymore, and they may be next...
Sorry about my ignorance,
Ian
#4 Posted : Wednesday, December 26, 2007 9:51:28 AM(UTC)
In order to check the igniter you have to disconnect the igniter wires (or cut them off).
Instead of testing the power to the igniter you can check the igniter continuity and if it's open, then the igniter is bad and has to be replaced.
The only what I can tell you is my personal technical advise. The decision if it's worth or not should be yours.
Happy New year!
david gentry
#5 Posted : Saturday, December 29, 2007 7:46:17 AM(UTC)
david gentry
I need help with my gas range,Its a sears kenmore model number 790.75715893.My problem is it takes too long for the oven to heat up.the higher the temp the longer it takes to heat up,lets say 450 degrees takes 45 mins please help me in finding the correct part i need to fix it
thank you david
david gentry
#6 Posted : Saturday, December 29, 2007 7:47:12 AM(UTC)
david gentry
my gas range takes too long to heat up
#7 Posted : Sunday, December 30, 2007 7:26:42 PM(UTC)
Hi David
How long takes to light up the burner since you turned the Bake "on"?
If it takes more then 60 seconds, then the problem is a bad bake igniter.
- The part number for the bake igniter is AP2150412
Happy New year!
Guest (6)
Kenmore oven not working after power outage (Oven Repair (including Ranges and Cooktops))
by Blue Cow 7/5/2009 12:39:47 PM(UTC)
Kenmore oven not working (Oven Repair (including Ranges and Cooktops))
by Van 12/22/2007 10:30:42 AM(UTC)
Kenmore Oven not working (Oven Repair (including Ranges and Cooktops))
by Jimnstella 11/19/2007 9:12:28 AM(UTC)
