volguy
#1 Posted : Wednesday, June 10, 2009 4:05:06 PM(UTC)
volguy
My GE Profile washer stopped working today. It will fill with water, but then wont start the agitating cycle. I removed the front cover and set it to spin. I see the motor try to turn but only turns slightly then stops. How do I determine which part may have gone out? This will be my first washer repair, wish me luck. :o
sidfink43
#2 Posted : Thursday, June 11, 2009 5:31:57 PM(UTC)
sidfink43
Could be several things
I would take off the belt and see if the motor operates freely. If it does, you will likely have to have the transmission/brake assembly replaced (it is a single unit, and not too expensive a part) but you will probably need a tech to do this.
If you want to try it yourself, try to get a service manual. GE is very tight with these, but you might find one on the net or on ********** for about $5.00.
Good luck, and let us know how it turns out.
volguy
#3 Posted : Saturday, June 13, 2009 12:56:42 PM(UTC)
volguy
sorry it took a while, but I checked it today and the motor does spin without the belt on it. whats the next thing to check?
sidfink43
#4 Posted : Saturday, June 13, 2009 2:38:00 PM(UTC)
sidfink43
With the belt off try turning the transmission pulley in each direction.
If it will not turn, you will probably need a new transmission assembly.
Good luck and let us know what you find out.
volguy
#5 Posted : Saturday, June 13, 2009 4:09:13 PM(UTC)
volguy
I dont know how much resistance it is suppose to have but one direction is easy (the agitator moves) the other direction is stiffer but moves the drum. I can move it both directions. Can the motor just not have enough power to move it?
sidfink43
#6 Posted : Saturday, June 13, 2009 4:39:37 PM(UTC)
sidfink43
Yeah, possible not likely.
It could be the clutch pulley, this part
Replacement parts for GE WPSR3100W2WW | AppliancePartsPros.com
which can only be really tested by replacement.
If you feel comfortable doing so, operate the machine with the belt off and observe the motor (you can empty it by moving the timer to the end of the wash cycle and engaging the pump). If you think the motor is ok, you can consider taking a chance with the above part.
Wish we could be more definitive. Good luck and let us know what happens.
volguy
#7 Posted : Saturday, June 13, 2009 4:51:59 PM(UTC)
volguy
if it will cost over 100-150 I might as well take a chance with a different washer. I was kinda hoping it would be a 25-75 problem. oh well. thanks for all your help.
sidfink43
#8 Posted : Sunday, June 14, 2009 5:11:58 AM(UTC)
sidfink43
Yeah, sorry, but we are dealing with GE here, the most expensive parts in the industry. I guess that's why they are still around, and companies like RCA are a distant memory.
Good luck with a new machine.
volguy
#9 Posted : Sunday, June 14, 2009 6:45:35 PM(UTC)
volguy
cant afford a new one, unfortunately with the economy and all. But I did get a free older washer that has a problem with filling. At least I can use this one for the time being. I posted the problem under washer repair, again. And again thanks for the help. I am learning a lot on this site already.:)
Guest (9)
ge profile washer wont spin or agitate (Washer Repair)
by mstrchief 10/16/2009 5:52:45 PM(UTC)
