davidqahpmedcntr
#1 Posted : Thursday, June 11, 2009 9:34:15 AM(UTC)
davidqahpmedcntr
I purchased Water Valve WR57X10032 for a GE Profile side-by-side. I need a drawing or instructions on how to disconnect and re-connect the 2 tubes which are marked DIS and ICE. They have no nut to remove.
woodchuckie
#2 Posted : Thursday, June 11, 2009 11:40:26 AM(UTC)
woodchuckie
Those are the quick connect connectors. You slide and hold the ring toward the valve and push the water line in all the way and release the ring. Removal is done the same way. If you have fittings on your water line just cut them off with a smooth cut not distorting the line.
