khubers
#1 Posted : Monday, December 24, 2007 6:06:06 AM(UTC)
khubers
We ran the cleaning cycle yesterday and following the cycle the door has remained in a locked position. We have tried turning off the breaker for a period of time (~ half hour) to see if that would reset it, but that was not a success. Is there a way to release the lock on the door?
#2 Posted : Monday, December 24, 2007 9:39:19 AM(UTC)
What it shows on the display?
khubers
#3 Posted : Monday, December 24, 2007 10:12:38 AM(UTC)
khubers
There are no messages in the display, other than the clock. The light associated with the lock is just continuously flashing.
misterfixall
#4 Posted : Monday, December 24, 2007 11:51:02 AM(UTC)
misterfixall
you will have to go to back and disconnect the latching motor. unplug stove , the problem may be with motor . or problem may be with clock. or both , ihave seen that happen with this model .observe motor with power on .see if it trys to turn.
#5 Posted : Monday, December 24, 2007 12:15:05 PM(UTC)
Try to turn the breakers off for a few minutes, turn it back on, start the clean cycle, wait a minute and cancel it.
Some times it helps.
P.S. If there is no error messages, the control does not sense any problems.
khubers
#6 Posted : Monday, December 24, 2007 3:09:32 PM(UTC)
khubers
Thanks for the suggestions. I have tried shutting down the breaker and restarting the cleaning cycle, but still have the same issue. I will have to take a shot at removing the back panel to take a look at the motor.
