hotbrick
#1 Posted : Sunday, December 23, 2007 2:56:09 PM(UTC)
hotbrick
Hey everyone,
Bought a house with a 5 year old side by side fridge and found a work order replacing a defrost timer about 2 and a half years ago. Well today the fridge quit working but freezer is ok. After reading in this forum I took the back out of freezer and found the coils froze up. I defrosted the freezer and that seemed to help. But I have a couple of questions
1 Is just defrosting a quick sollution?
2 Is it normal for a timer to go out in a couple of years?
3 Do I need to replace timer AGAIN or something else?
Thanx....hotbrick
abbie
#2 Posted : Sunday, December 23, 2007 6:40:53 PM(UTC)
abbie
The first answer to the question is that defrosting coils will not solve the problem .It sounds like you have a defrosting problem which can be one of three things, that,s if it,s not and electronic fridge.First it could be the timer or defrost thermostat[bi-metal] or the heater If you know where to find the timer,you can manually set in into defrost by turning the center button of the timer slowly clockwise until the fridge shuts off this is when it will be into defrost. Put you ear into the freezer section and listen for cracking and hissing noises after a few minutes. If you here this ,then your timer is bad.BUT if you here nothing then it could be you bi-matel or your heater, To check these parts you could jump the bi-metal when the freezer is cold inside,or check with a meter both bi-metal and heater to see if there is continity. BUT IF YOU JUMP THE BI-METAL AND FIND THE HEATER TO WORK DO NOT LEAVE IT JUMPED. REPLACE THE BI-METAL WITH A NEW ONE , BECAUSE THE BI-METAL IS A SAFTY DEVICE... GOOD LUCK
hotbrick
#3 Posted : Sunday, December 23, 2007 6:48:02 PM(UTC)
hotbrick
Thanx for the quick reply abbie. Everywhere I read on this site says that it might be my defrost timer. Is there a good site (maybe this one but cant find it) where I can look at a cross section of my fridge to see where these parts are located??..Thanx
Fridge is warm but Freezer sometimes warms up (Refrigerator & Freezer Repair)
by tsamm 7/19/2021 1:23:46 PM(UTC)
Top of fridge is warm, lower freezes everything! (Refrigerator & Freezer Repair)
by briandren 8/5/2017 12:55:25 PM(UTC)
Freezer cold but fridge is warm (Refrigerator & Freezer Repair)
by nmnative71 8/5/2015 10:49:10 AM(UTC)
Top of Freezer and Fridge is warm (Refrigerator & Freezer Repair)
by setnamyor 8/1/2014 2:21:03 PM(UTC)
Freezer is cold but fridge is warm (Refrigerator & Freezer Repair)
by janec2121 4/28/2014 8:34:59 PM(UTC)
Freezer works/fridge is warm??? (Refrigerator & Freezer Repair)
by jblake 4/7/2013 8:33:12 AM(UTC)
Fridge is warm freezer cold (Refrigerator & Freezer Repair)
by Suzanne brugger 8/28/2012 2:39:42 PM(UTC)
fridge is warm, no water in defrost pan (Refrigerator & Freezer Repair)
by jdoliver 7/7/2012 11:21:00 AM(UTC)
Fridge is warm, freezer is still ice cold! (Refrigerator & Freezer Repair)
by sumrtyme 3/27/2012 11:35:17 AM(UTC)
Side by side freezer works but fridge is warm (Refrigerator & Freezer Repair)
by Kell7348 12/10/2011 8:26:53 PM(UTC)
Freezer Working, Fridge is warm again (Refrigerator & Freezer Repair)
by DCapo 10/9/2011 4:18:08 PM(UTC)
fridge is warm freezer is fine (Refrigerator & Freezer Repair)
by harry06 7/5/2011 4:28:39 PM(UTC)
Freezer works fridge is warm (Refrigerator & Freezer Repair)
by Hagar714 6/27/2010 9:11:23 AM(UTC)
Fridge is warm!!! (Refrigerator & Freezer Repair)
by black3144 4/25/2010 9:56:11 AM(UTC)
Fridge Is Warm, Freezer Still Works( PLEASE HELP!!!) (Refrigerator & Freezer Repair)
by mnb831 4/1/2010 3:20:45 PM(UTC)
