mattharper76
#1 Posted : Sunday, June 7, 2009 6:54:10 PM(UTC)
mattharper76
We have a GE side by side that stopped cooling this afternoon. The internal freezer fan is running. Could it be stuck in a defrost cycle? As far as I can tell there are 4 main parts controlling the temp: a temp sensor, a defrost thermostat, a circuit board at the temp knobs, and a mother board on the back of the machine. The compressor is not running but I am guessing that is because the brain is telling it not to. Our fridge was part of the frozen door recall/repair. This fridge has not been moved since purchased 7 years ago. No other service has been preformed other than door replacement.
GeorgeS
#2 Posted : Sunday, June 7, 2009 7:19:09 PM(UTC)
GeorgeS
I'm not an expert in this, just wanted to share my recent experience.
My fridge started clicking recently and the compressor would not start. After I unplugged the fridge, vacuumed the condenser coils (they were really dusty), and plugged the fridge back, the compressor started and seems to work fine now. Further investigation lead to the failed motherboard, but this is a different story. What I wanted to ask is if your condenser coils are dusty or not? If so, may be just cleaning them will help start the compressor, and you can go from there. Please don't forget to unplug the fridge if you are going to clean the condenser coils.
George.
mattharper76
#3 Posted : Monday, June 8, 2009 4:09:42 AM(UTC)
mattharper76
Coils are clean. usually clean them about once a year.
woodchuckie
#4 Posted : Monday, June 8, 2009 6:32:03 AM(UTC)
woodchuckie
When the unit shuts down for defrost, the fan in the freezer also shuts down.
I would check the starter/overload relay for the compressor.
williammix
#5 Posted : Monday, June 8, 2009 6:56:46 AM(UTC)
williammix
onece a week i have to defost the freezer,so it will keep bottom cool
woodchuckie
#6 Posted : Monday, June 8, 2009 1:17:37 PM(UTC)
woodchuckie
For auto defrost failure
check defrost timer, defrost heater, defrost thermostat> Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Most new models don't have a timer and have an adaptive defrost control.
If the heater and thermostat are ok it’ll be the control.
mattharper76
#7 Posted : Friday, June 12, 2009 6:19:47 PM(UTC)
mattharper76
replaced main control board. at the advice of a friend I took the board out of the back and noticed a black spot on the board.
Fixed problem immediately.
Guest (5)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
