AngieAH
#1 Posted : Friday, December 21, 2007 12:28:08 PM(UTC)
AngieAH
My washer has gone mad! It first started out it would stop after wash cycle and would not drain unless I lifted the lid several times. I bypassed the lid switch to see if that was the problem. Not! It continued to stop after wash cycle and I could press the start button twice and it would drain and continue cycle. I then could unplug it for the 2 minute reset time as on manual and press start and it would allow 2 washes then would have to be reset again. Would on at least one of the washes stop after washing when its supposed to drain like before, I replaced the pump, worked great for 2 washes, after these washes the start button blinks and it will do nothing unless I unplug again for the 2 min reset. Can someone help me with this? I will never buy another GE, I just replaced 2 months ago the key pad on my oven and now this grimlin has come to haunt me.
#2 Posted : Friday, December 21, 2007 12:51:54 PM(UTC)
Most likely the problem with your washer is a bad control board.
- The part number for the control assembly is AP3187284
- Here are the break down diagrams for the GE washer Model WPSB8060B0WW
Good luck.
P.S. It does not matter who made it. It could happen to any computerized appliance.
AngieAH
#3 Posted : Friday, December 21, 2007 1:16:09 PM(UTC)
AngieAH
Thanks Gene, order'd the part. I have to say I have had more than my share of problems with GE, my cooktop, my frig, wall oven and now my washer. I do believe when these are dead its time for a change. I've heard LG is good what are your thoughts? Also will not get anything with key/touchpads! Going back to basics.
#4 Posted : Friday, December 21, 2007 1:26:12 PM(UTC)
LG appliances are good as long as nothing breaks. In most cases the service could be provided by an authorized technician only and if you are in a small town it could be a serious problem. And if you are going back to basics then LG is not for you.
Happy Holidays.
richappy
#5 Posted : Friday, December 21, 2007 4:20:54 PM(UTC)
richappy
In a lot of appliance electronic pc boards they use small undersized relays and triacs that just don't last.
I am very impressed with the Whirlpool front loader washers, nice heavy duty relays and electronics that don't fail often.
