3 Pages<123>
abbie
#11 Posted : Thursday, December 20, 2007 7:56:26 AM(UTC)
abbie
Russ i,am sorry for your troubles. Russ when the fridge goes into this mode when the fan stops,can you see what the evaporator coil look like. Are the coils frosted or are they sweaty or wet?
richappy
#12 Posted : Thursday, December 20, 2007 8:13:33 AM(UTC)
richappy
All the symptoms point to an evaporator fan going sour, just go and replace it by clicking on your model # above.
Russ
#13 Posted : Thursday, December 20, 2007 4:39:34 PM(UTC)
Russ
Reply to Abbie: Thanks for your condolences. I cannot see the evaporator coils, there is no frost/sweat on the back wall of the freezer.
Reply to Abbie & Richappy: The next time it goes into this mode of operation, I'm going to remove the back wall and check for frost etc, I'll also ckeck to see if there's power to the evaporator motor. If there's power, I'll know the motor is failing intermittanly. If there's no power then I'll need some more suggestions from you guys which I greatly appreciate. Its very difficult to troubleshoot without a wiring diagram.
Regards,
Russ Stevens
misterfixall
#14 Posted : Thursday, December 20, 2007 6:30:03 PM(UTC)
misterfixall
possibly there is a intermitant restriction of freon gas in refrigeration lines, only a tech with can know for sure
richappy
#15 Posted: : Thursday, December 20, 2007 6:41:34 PM(UTC)
richappy
That makes a lot of sense, a temporary restriction in the capillary would make the freezer warm and then the evaporator defrost thermostat would open, thus stopping the fan! I had one once, rosin got into the capillary and I blew it out with my propane torch!! In this case, the dryer screen, or lack of one, is not preventing particles from the compressor getting into the capillary tube.
One way to detect this is a overheating compressor, condenser warm, not hot, and low compressor current.
abbie
#16 Posted : Friday, December 21, 2007 5:11:30 AM(UTC)
abbie
OK Guys, here we go again back to the bi-metal please tell me how this part can stop the fan motor from working when it,s open. This part is in SERIES with the defrost hearter. Maybe I not getting it. Is there a second bi-matel that i,am not getting.If so please tell me..
kawfeeman
#17 Posted : Friday, December 21, 2007 6:08:09 AM(UTC)
kawfeeman
Rank:: Advanced Member
when the evap fan is not running what does the evaporator itself look like ?? is it full of ice ? is the evaporator fan free ?? there is a round device "clipped" on to the evaporator itself and that is called a defrost t-stat or termination defrost t-stat .. ( prevents over heating in defrost ) IT ALSO DOES NOT ALLOW THE EVAPORATOR FAN TO COME ON UNTIL THE EVAPORATOR IS COLD ENOUGH !!! ... check to make sure the evap fan is not getting stuck, heating up and not turning ? also the defrost t-stat should be jumpable , in other words, you could temporarily put a jumper between the wires / plug that supplies voltage to the defrost t-stat (switch) ...
abbie
#18 Posted : Friday, December 21, 2007 6:46:20 AM(UTC)
abbie
The Defost Bi-metal Doesn,t Control The Fan It,s In Series With The Heater .when You First Start A New Fridge Does The Fan Come On [yes] Is The Defrost Bi-metal Open [yes] Until It Gets Cold In The Freezer Is When The Bi-metal Will Close.. This Is My Last Post On This Matter....
kawfeeman
#19 Posted : Friday, December 21, 2007 7:35:18 AM(UTC)
kawfeeman
yea.. i think so also.. just does NOT seem like a compressor problem !
richappy
#20 Posted : Friday, December 21, 2007 12:34:45 PM(UTC)
richappy
The older GE fridges and Amana wire the evaporator fan motor in series with the defrost heater and defrost thermostat and both fridges when started up did NOT power up the fan till the t stat closed when the freezer got down to temperature. Evaporator fan draws maybe .1 amp, voltage drop across heater only about 3 volts, not enough to effect operation.
Freezer Problems (Refrigerator & Freezer Repair)
by CJPolinsky 12/6/2016 4:09:14 PM(UTC)
GE fridge freezer problems (Refrigerator & Freezer Repair)
by robinleigh 2/16/2016 5:33:39 PM(UTC)
GE Bottom freezer problems after main board swap (Refrigerator & Freezer Repair)
by Busy 9/25/2015 9:05:47 AM(UTC)
25326442100 Kenmore Freezer Problems (Refrigerator & Freezer Repair)
by cover 5/21/2015 6:47:34 PM(UTC)
by Bill120 9/2/2014 12:41:21 PM(UTC)
Freezer problems (Refrigerator & Freezer Repair)
by GaryPil 4/21/2014 9:31:00 AM(UTC)
Whirpool Freezer Problems (Refrigerator & Freezer Repair)
by Eds 3rd 9/3/2013 7:34:01 AM(UTC)
by jclisk 9/6/2012 7:44:55 PM(UTC)
by dymetz62 5/19/2012 4:48:18 PM(UTC)
by Pop 12/1/2011 2:05:32 PM(UTC)
Chest Freezer Problems (Refrigerator & Freezer Repair)
by rhondap 7/12/2011 1:07:11 PM(UTC)
Frigidaire Freezer problems (Refrigerator & Freezer Repair)
by trountre 6/28/2011 7:50:02 AM(UTC)
by maxepr1 2/26/2011 8:34:28 AM(UTC)
by danno621 7/13/2010 3:08:48 PM(UTC)
whirlpool freezer problems (Refrigerator & Freezer Repair)
by wally28 4/8/2010 5:17:19 PM(UTC)
3 Pages<123>
