3 Pages123>
JST
#1 Posted : Tuesday, December 18, 2007 4:22:29 PM(UTC)
JST
All four stove top burners work but the oven touchpad does not work. No errors displayed, clock is working but can not set the time. Reset the power with no change.
kawfeeman
#2 Posted : Wednesday, December 19, 2007 4:40:10 AM(UTC)
kawfeeman
just curious, was this after a self cleaning cycle ?
JST
#3 Posted : Wednesday, December 19, 2007 10:52:15 PM(UTC)
JST
Yes it was the day after a self cleaning cycle.
kawfeeman
#4 Posted : Thursday, December 20, 2007 6:14:35 AM(UTC)
kawfeeman
are you ok with disassembling the clock / touch pad ? check all connections to / from clock / touch pad and make sure nothing is broken.. strange there are no fault codes though... does any button give a response at all ?
JST
#5 Posted : Thursday, December 20, 2007 7:05:35 PM(UTC)
JST
Checked all connections, all good. Can hold Bake and broil and get into the settings mode, can also enter the "show room" mode, clear button beeps but nothing else.
Thanks,
JST
#6 Posted : Wednesday, December 26, 2007 9:55:02 PM(UTC)
JST
Jim,
Is there anything else I should check? Self cleaning switch or lock perhaps?
J
kawfeeman
#7 Posted : Thursday, December 27, 2007 12:52:20 AM(UTC)
kawfeeman
sounds as if there is a bad connection or a comm error .. tried removing touch pad cable ( power down then power back up again and see if there is any fault that comes up ? )
JST
#8 Posted : Saturday, December 29, 2007 1:00:15 AM(UTC)
JST
Pulled the touchpad and controll board out checked all connections, did a resistance check on the touchpad and everything reads what it should according to the scat in the stove but between pins 5 and 9 on the ribbon cable I read a short. Five and nine do not equate to any number but could they be messing things up? Still no error codes.
Thanks again,
Jason
JST
#9 Posted : Sunday, January 6, 2008 9:27:09 AM(UTC)
JST
Thanks again,
Jason
#10 Posted : Monday, January 7, 2008 8:09:58 AM(UTC)
Most likely the key panel is shorted out and has to be replaced.
- The part number for the black key panel is AP3205170
Good luck.
Guest (12)
3 Pages123>
