2 Pages12>
Clintr
#1 Posted : Monday, December 17, 2007 6:06:23 PM(UTC)
Clintr
My oven will not light when I turn it on, I do not smell gas so I was wondering if it was the T-Stat for the oven?
#2 Posted : Monday, December 17, 2007 6:40:13 PM(UTC)
There are two different kind of the oven ignition for the same model number shown.
Open the broiler door and look inside to find if there is a standing pilot or an oven glow coil igniter.
Post your findings, please.
Clintr
#3 Posted : Tuesday, December 18, 2007 3:18:42 AM(UTC)
Clintr
Yes I already checked for the pilot light, it is on. I did not smell any gas when I turned the knob, so I figured no signal was getting to the valve or T-Stat.
#4 Posted : Tuesday, December 18, 2007 10:17:54 AM(UTC)
I need you to monitor the pilot light while you turn the thermostat "on" to see if the pilot light will extend.
Post the result.
Clintr
#5 Posted : Wednesday, December 19, 2007 3:16:53 AM(UTC)
Clintr
Yes the flame does extend when I turn it on, I checked with an Appliance co. and they said it could be the safety valve. They told me to disconnect the gas line and tap on the valve to see if it loosens up any sediment and reconnect it and try to see if it lights, is this safe?
kawfeeman
#6 Posted : Wednesday, December 19, 2007 4:19:21 AM(UTC)
kawfeeman
i would assume they want you to do that with the gas supply off hopefully
Clintr
#7 Posted : Wednesday, December 19, 2007 10:34:44 AM(UTC)
Clintr
Yes you are right, with the gas off. Do you think this could be the problem?
#8 Posted : Wednesday, December 19, 2007 12:00:05 PM(UTC)
I do not think it was a good idea. The gas safety valve is a safety devise and it's better not to play with it.
Just replace the gas safety valve and get back in business.
- The part number for the gas safety valve is AP380403
Good luck.
kenjg
#9 Posted : Thursday, December 20, 2007 10:13:00 AM(UTC)
kenjg
I have the same problem. I have a double oven old Hotpoint model RGH558U. The top oven and range burners all work properly. The bottom oven has stopped working. The pilot light is lit but there seems to be no gas going to the burner pipe?
#10 Posted : Thursday, December 20, 2007 12:33:55 PM(UTC)
Hi kenjg
Unfortunately all of the parts for the lower oven ignition system are no longer available.
Guest (8)
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
2 Pages12>
