bmwdrvr
#1 Posted : Wednesday, June 26, 2024 6:56:03 AM(UTC)
bmwdrvr
I have a Dacor built in refrigerator DYF48BIWS00 and the Ice maker has stopped running. I have replaced the ice maker and this did not work. I tested the voltage at the wiring harness, with the door closed and get 5-7 volts. I bypassed the inline fuse and get the same reading. Please let me know what else I can check. Thank you.
WilliamM/APP Team
#2 Posted : Wednesday, June 26, 2024 10:42:12 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
Was thanked: 14 time(s) in 14 post(s)
Bmwdrvr, thank you for your question. As this is an optics-regulated ice maker, is the receiver W10757851 on the right side receiving 120VAC at the black wire? Also, has the temperature of the freezer been verified as being below 10°F with a thermometer?
Edited by user Wednesday, June 26, 2024 10:42:52 AM(UTC)  | Reason: Not specified
bmwdrvr
#3 Posted : Thursday, June 27, 2024 6:20:15 PM(UTC)
bmwdrvr
The receiver has 7 volts, same as the ice maker. The freezer is < 10°F per a thermometer.
WilliamM/APP Team
#4 Posted : Friday, June 28, 2024 5:57:27 AM(UTC)
WilliamM/APP Team
If the door switch operates properly and is verified through continuity testing, the most likely cause of failure would be in the main control WPW10200659. The main control should be sending 120VAC through the yellow wire with a red stripe at connection P5.
