Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a GE JUNK too. I have replaced the dump solenoid and the timer $ times in 18 months and it just did it again. This is how they make their money. They are the Cabal, Just like the rest of the Reptilians that is ruling our world. TheGreatAwakening.org to find out more about the fall of the Cabal.
May 14, 2023 I have the same problem, replaced the drain solenoid and it burned up. I always thought this was caused by the timer, so I have one ordered and an another solenoid. My dishwasher is a GE, and going on 9 years old. I thought about replacing the dishwasher with a new one, but at about $600 plus I thought I would try repairing the old one. So far I have about $150 in parts.
]ust Letting people know, DO NOT BUY G.E. It IS PURE JUNK. G.E. Is Part OF THE CABAL (DEEP STATE) they delibritly make products to fail to keep you broke. I was a SUCKER TOO!!! I have a G.E. Dishwasher and have had it 2 years and have replaced the drain solinoid and timer 5 times in the 2 years.
So Don't be a sucker like
I'm not so sure it's the timer's fault. I got a work order in for a dishwasher that won't drain.
Funny thing is when I got it, it wouldn't fill or drain. The water inlet valve was stick closed, and the drain solenoid was melted closed.
I installed brand new parts. The water goes in and goes out half as fast.
Confused, I check the solenoid. It was binding about 2/3rds the way in. I tried WD40 and it improved the movement, but did nothing for the binding.
Perplexed, I inspect my brand new part from GE and I notice that the actuator (the metal part of the solenoid) is milled to for the home perfectly.
This is not good, because the hole is a plastic columns and the metal bottom is air tight. Thus condition causes a vacuum resistance when the spring tries to pull the actuator back out of the coil. Think when a full trash bag is difficult to remove from a trash can.
So, I took a file and filed down the bottom half of the actuator so air can get pass.
That solved the binding issue
After making the modification, I now wonder if I could have taken my Dremel and just made a single shallow notch from the bottom to the top of the actuator and achieved the same result.
