Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Trying to figure out how to stop the water that dribbles constantly from soap dispenser on inside of tub on GE Cafe dishwasher drawer. Model # CDD420PT0S1
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
The detergent dispenser module WD12X30914 is likely allowing rinse aid to leak by. This can be caused by a failed dispenser module, or by the wash control module WD21X31483 continuously sending voltage when it should not. The dispenser would need to be tested for voltage. If voltage is present, the wash control module would need to be replaced. If no voltage is present during the leaking, the dispenser module would need to be replaced.
