Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Also I checked the system pressure at the well pump switch and it shuts off (max pressure) at 45 psi. This is kind of low already so I did not adjust it.
I planning on throttling the water inlet to the washing machine because this seems to be the only way to stop the leak out the soap drawer but an concerned about the effect on the machine?
Are you ready to level up your social media game? To find the best services and boosts for your profiles and enterprises, check out SMM Tribe, the fully automated SMM panel. Increase your profile's stature on the web with help from Instagram's likes, comments, views, and more. In addition, there are a plethora of tools at your disposal to help you improve your profile across social media sites like YouTube, Facebook, TikTok, Twitter, Telegram, Spotify, Twitch, and even LinkedIn. If you're an influencer, a business owner, or just someone who wants to see their social media presence expand, SMM Tribe can help. Intriguing, right? Now that everything is taken care of automatically, you can relax and watch your social media following grow. Don't waste any more time getting the social media results you want; join the SMM Tribe now. https://smmtribe.com/ref/f2cdjEdited by user Friday, April 28, 2023 9:01:50 AM(UTC)
| Reason: Not specified
Same problem here. It had been going on for about a year when I finally saw the water coming from the soap dispenser. I cleaned everything but didn't fix the problem. I throttled back the water until it was open, only 1/4 turn. It reduced the problem slightly but didn't fix it.
I finally checked the level of the machine and found the installers had not bothered to level it. It was pitched forward about 3/4 to 1 inch lower the front causing any excess water in the soap dispenser to run out the front instead of into the back drain. I leveled the machine properly, and the problem went away. We've used it for about a week now without any leaking.
The installation instructions say nothing about leveling the machine and how important it is to prevent the leak.
I hope this helps someone else to fix their soap dispenser leak.
We are having the same problem. I’ve ordered a new soap drawer assembly. But it’s completely random, though. It does seem to happen most on a rent cycle, and less likely when I mark the soil level as light.
Water is continually leaking from my detergent tray. Even after the power is off...in my Lg profile washer
