Our LG fridge is 6 years old and about a month ago, I noticed freezer was not getting as cold and all the ice melted. I called a technician but suddenly fridge started working again after a day so I cancelled the service call.
Fridge worked normal for 2 weeks but it is having the same symptom again. Freezer is not cold enough.
Do I need to change my defrost sensor and thermostat? Main board?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 Location: TN Was thanked: 14 time(s) in 14 post(s)
As the appliance is resetting itself, likely from the power cord being unplugged for a few minutes and then being plugged back in, the failure would most likely be the main control.
