Don49
#1 Posted : Friday, March 15, 2024 12:21:35 PM(UTC)
Don49
We have a Kenmore 56703500 Side-by-Side refrigerator – probabaly 10+ years old. About a year ago we noticed a water leak, and the repair technician spliced the water line right where it enters upper panel area. He said we shoujld consider a new fridge, because if the supply line ever starts leaking the back of the fridge would have to be removed.
I replaced the water inlet valve about 4 months ago. While doing so, I noticed that the water line (noted with arrow) had a repair slice right where the line enters the upper panel. I would like to replace this line, but have no idea how to remove/replace it because the way the line is routed anddissappears into the back of the fridge.
There must be a way to do this. Any ideas?
[img=https://drive.google.com/file/d/1F4r8JJq7FoPBaUOdFJDRdjnMgpxm048q/view?usp=sharing]Fridge[/img]
Ed C/ APP Team
#2 Posted : Tuesday, March 19, 2024 9:48:55 AM(UTC)
Ed C/ APP Team
Groups: Moderators, APP Team, Registered
Don49,
The link that was on the post will not pull up. If this is the water line that goes from the water valve and up the back of the refrigerator near the top then you would need the fill tube to the icemaker. This would need to be pulled out from inside the freezer after the icemaker has been removed. Here is a link to the part. If this is not the correct line then if you can get a good description where this would be running to we can help better. https://www.appliancepar...wp2256096-ap6006836.html
Don49
#3 Posted : Monday, June 10, 2024 4:56:36 AM(UTC)
Don49
The line leaves the water supply valve, but enters/dissappears into the cabinet back. See photo: https://drive.google.com...xm048q/view?usp=sharing. It appears that the cabinet back is help in place by rivets, so removing the back panel would be near impossible. Am I missing something?
Don49
#4 Posted : Monday, June 10, 2024 10:39:07 AM(UTC)
Don49
I should lso mention that the icemaker seems to be working, however the front/in-door water supply does not provide water.
