brandinm
#1 Posted : Saturday, February 10, 2024 5:09:13 PM(UTC)
brandinm
Dryer will power on but not start. Depending on the dryer setting it will click 1-3 times, it did this before I changed the thermistor but stopped and it started doing it again after I got the new control board.
I have fixed what I know wasn’t working but I’m at a standstill.
Error code TE1 I changed the thermistor and it was bad it was checked with a meter
Fuse was reading 0.1 and I believe that is okay
Control board would not read so ordered a new one the new one picks up on the meter so I know it works.
Belt is on nicely like it should be.
Should I keep trying to fix it or just get a new one?
Single mom don’t really have the money to replace it or pay someone to fix it so trying to diy it.
Jason O
#2 Posted : Tuesday, February 27, 2024 7:28:00 AM(UTC)
Jason O
Groups: Moderators, APP Team, Registered
Hello, since you have already changed the main control there are just a couple of things that would stop it from running. The door switch, belt switch, and motor itself but with the clicks you are hearing I would suspect an issue with the PCB assembly.[AP6799342]. Unfortunately, this part has been discontinued so the repair cannot be done.
