Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a Frigidaire dishwasher that isn't filling with water. I replaced the water inlet valve and it still didn't fill. I tested both the new and old valve for continuity and both did NOT have continuity. Neither did the main circulation pump, so I replaced it too. Still doesn't fill with water. But I know the new pump works because if I manually put water in, the pump sprays the water. Could I have received a bad valve as a replacement?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
If the model number of your appliance could be provided, this will allow the most accurate information to be presented.
