Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Keep getting a "be" error code. I used the correct detergent, tried the milk trick , leveled and turned off the power for 24 hours. I spoke to a rep and they said to run an empty load with just water. Still nothing- code keeps coming up just before drying cycle. How does machine sense over sudsing?. Any luck out there with this issue?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
If the model number of your appliance could be provided, this will allow the most accurate information to be presented.
