Maytag Bravos XL
My laundry room only has cold water available. Washer is getting error code LF. Is there a way to bypass this error without connecting hot water.
I am not acquainted with this model but my guess is that the washer senses that you are only providing water to the cold side and not making a connection to the hot side connector. You might want to get a splitter hose connector and use that to provide a water connection to the now vacant connection. As an alternative to verify the washer function try switching the hose connector from the cold side to the hot side connection.
