My washer will not drain. I did the diagnostics test and it throws the code for drainage issue. I replaced the drain pump and that was not the problem. What other issues could be causing the drain problem? I’ve flushed it quit a bit with testing the pump. Seems anything plugging has come out. Could this be my circuit board? It seems like the washer isn’t communicating to the pump to activate it.
