I got the Same issue 3 pumps in as many years.
I’m on my 9th pump now and I’m to the point where I just keep a couple of spare ones in the drawer so I can keep replacing them and when I use the last one I order 3 more
I'm on my 3rd pump in 5 years! No more LG!
I have the same issue. Bought washer 21 April 2017. Replaced water pump 18Jun2020, 22Oct2021, and 01Jan2024 it is bad again. How can LG be the Consumer Reports top rated models with this sort of defect? How bad can the other models be?
SAME issues. Replaced drain pump 4 times in the last 3 years. Have to replace again only 6 months after replacing.... LG dishwashers have the SAME problem with their drain pumps.
Will NEVER buy LG products again.
Has anyone heard of a recall for the LG washer combo? Because, the original drain pump lasted for a year. now I find myself replacing it every two to three months. It may be a easy and cheap fix, but that does add up.
Originally Posted by: Guest I've had the same issue as everyone else - the impeller breaking off. I'm currently on my 2nd replacement impeller. For the third go-around, which I'm sure will come soon, I made a beefed up, 3d printed impeller. I used PETG as the material. Here's the files on grabCAD. --) https://grabcad.com/libr...er-drain-pump-impeller-1Hope it helps someone out.. If it works can you sell it on Etsy? I bought a gear for my pencil sharpener on Etsy … worked perfect! Kevin
On my 5th one…. It’s a royal pain in the a%* to keep replacing them… they go every 6 - 8 months and I only do 2-3 loads a week,,,
As a work around, we emptied the washer by collecting water of the drain pump hose while the machine ran spin cycle. Have a couple empty containers because they fill up quick!
I found a permanent fix. Never buy an LG product ever again. Going on my 4th or 5th pump. One only lasted literally 3 months. Garbage is s garbage does.
