I Have a GE xl44 Gas range that has no power. clock blank, oven light will not come on, igniter will not strike. I have 110 at the outlet, and going into the stove. There is power going to the control panel. I have unplugged several times and plugged back in after 30 minutes. Still nothing. I think it is the control panel, but I want to be sure, before I buy one. Any help? Please. The model number is jgbc20wea5ww. Thanks
Groups: APP Team
Hi.
It doesn't seems to me that you are getting 120VAC to the internal parts of the range.Trace the power to the unit and from the block to the clock and up the wiring on both L and N.
Thank you. Post the results.
Simon.
Thanks. That was the problem. Thought I had 110 at the outlet but Only had about 80 VAC at the outlet. Fixed that and it works great. Thanks so much!!
Groups: APP Team
You are very welcome.
Simon.
Originally Posted by: JOHNTHACKER  Thanks. That was the problem. Thought I had 110 at the outlet but Only had about 80 VAC at the outlet. Fixed that and it works great. Thanks so much!! How did you adjust it to 110? I am super new to all this.
