Replaced direct drive transmission with a new oem part. The washer agitates as it should. At the end of the agitation the washer pasues with its normal wait period. The neutral drain begins but runs for about 2 seconds then jumps into the spin cycle with the tub still filled with water. Tried all washing cycles on the machine and it does it each and every time. Is this a bad timer or did I get a bum part? Before replacing new, old transmission drained correctly. I replaced because I thought I had an agitation issue with old transmisson. Edited by user Saturday, July 15, 2023 12:00:11 PM(UTC)
| Reason: mis-spelled word
Joined: 12/4/2022(UTC) Posts: 0 Was thanked: 1 time(s) in 1 post(s)
did you calibrate the machine
