2 Pages<12
Guest
#11 Posted : Monday, July 10, 2023 4:19:27 PM(UTC)
Guest
Originally Posted by: brad65 Go to Quoted Post
If you have a Bosh gas or electric range with a touch pad above the burners and it stops working.....first thing, remove the top rear sheet metal plate at the back (2 screws) and look and see if the circuit board has come away from the front panel...Bosh uses 2 sided tape to secure the display panel and it can become loose and your oven and clock won't work....
All ya have to do is press it back into place and maybe add some duct tape to the outer flanges to hold it better.....
Good luck..
I had same problem. Light,time and off was not working on Bosch electric stove. Followed above instructions and panel was unglued. Pressed it back in and put tooth pics to hold top and bottom of panel and then put duct tape over. Works perfectly. Saved me over $300.00.
Thank you very much for this post.
2 Pages<12
