Oven was working fine.I wasn’t home,but a friend was there.The gas company worker decided the oven was not safe.The dial that controls the temperature and broiler.It was faded and not really lined up as accurately as it should be.You would just zero it out on the off end and listen quietly for it to go off.He disabled it and red tagged it for safety.If I would have been there,I could have showed him how I could make the gas from coming on.So my question is what did he do to disable gas flow?
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Sometimes there is a shutoff behind the range, sometimes they disconnect the supply line and cap it. Just be careful and always error on the side of caution when dealing with gas.
I used to test the oven temp and after many cycles, I'd mark the dial with a paint marker or scratch it right into the dial face.
This is why you never let the gas company in your house. I just tell them NO. No pilots to light, no thanks. Good try, now go away.
