Bake, Broil and Keep Warm buttons do not work. Clock, Clean and other buttons do!
Originally Posted by: Karin Feeney ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Bake, Broil and Keep Warm buttons do not work. Clock, Clean and other buttons do! Since Clean works, it is not the thermal fuse which is an over temperature protection feature. Which narrows it down to your touch panel/control....or maybe thermostat. When you say Bake / Broil / Warm buttons don't work, do you mean the oven doesn't work on those settings, or when you touch the button there is no response (beep or temp setting active) from the touch panel ?...and there is a response from the display for Clean/clock and the number panel. If the touch panel "beeps" and you can key up a temp but the oven never turns on, then your control is dead OR the thermocouple (sensor) /thermostat (switch) is dead. thermocouplethermostat are easy to check with Ohm meter. The reason Clean works is because there is no on/off...it is just ON. if the touch panel doesn't respond then the touch panel is dead. Also, your header info needs complete Model # MEW 5530 for electric...or MGW 5530 for gas Replacing front Panel Control (face plate with touch pad) is easy...a few screws and disconnect ribbon wires. Replacing Control Clock H1 panel is also very easy....a few more screws and a few more plug in modular wires but all very simple.
My bake button wont respond, or my broil button. Rapid preheat button beeps twice when i press it
None of my buttons on my oven work but the cancel button. How can I fix this issue?
Joined: 12/4/2022(UTC) Posts: 0 ![Canada Canada](/Content/images/flags/CA.png) Was thanked: 1 time(s) in 1 post(s)
only cancel button works eh. I want to know how to fix too.
i once saw a video cleaning the connection to fix your issue but never tried it
My bake button doesn't come on. Broil button works. What is wrong with bake button?
My oven panel says OFF and doesn’t respond when I push any buttons to start baking etc
