Joined: 1/12/2023(UTC) Posts: 0 Location: South Carolina
I have searched this forum, youtube, and Google for my issue as it is common. I have replaced the 4 suspension rods and the hub adapter plate under the agitator. This is thing is still jumping like crazy and it doesn't matter how much is in it. Sometimes it will be fine then other, like right now, jumped with only 3 items in it. It is only 3 years old and started this mess a couple months back. What else could be causing this?
How much play should there be in the transmission? When looking straight down on the tub, the center of the shaft is moving a good bit. Is there some kind of mount that could be causing it? The balance ring at the top of the tub still have fluid in it as well.
This will for sure be the last Maytag/Whirlpool appliance I buy.
Joined: 12/4/2022(UTC) Posts: 0 Was thanked: 1 time(s) in 1 post(s)
i have bad experience with new maytag as well
most common cause could be not level and legs damaged.
