tseibring
#1 Posted : Sunday, January 8, 2023 7:57:44 AM(UTC)
tseibring
I have a GE dryer that's not heating. I checked the element and thermal fuse. All good
When I checked the thermistor I got 163.7k.I assuming that's to high. The numbers on it is T-105j 76j1hx0007. Which I can find that number. 134587700 is the only number I see when looking for the original one. The problem is, the prongs on it are wider then the T-105 thermistor. I need advice? Thanks
ThatGuy
#2 Posted : Sunday, January 8, 2023 9:18:57 PM(UTC)
ThatGuy
I tried looking up that part no. 134587700, that is a Frigidaire part. The only thermister I found for your model number was this...
https://www.appliancepar...t-we4m550-ap5793568.html
Does it look like this one?
https://www.searspartsdi...u0ut-0026-363/id-we4m550
It might be a thermister problem or it might be a bad relay on the board or possibly a bad switch on the motor. I really don't know very much about this model and brand of dryer. I just volunteer some of my time to try and help if I can.
This will sound redundant, but make sure you have 240 volts AC to the dryer. A lot of dryers will tumble and seem to be working while only having 120 volts to them. You need the full 240 to heat. I used to see it all the time on service calls.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Dryer runs for 5 -15 mins, no heat, wont turn back on (Dryer Repair)
by cavalry577 12/4/2017 6:06:31 PM(UTC)
Spins, no heat, no ignitor glow - Whirlpool Estate gas dryer (Dryer Repair)
by ithryn 6/30/2016 3:03:52 PM(UTC)
No Heat, Continuity good! (Dryer Repair)
by Hawaii Guy 808 4/11/2015 4:57:28 PM(UTC)
No Heat, Fried Wires (Dryer Repair)
by castertvs 10/7/2014 7:42:43 PM(UTC)
dryer no heat, doesnt turn off (Dryer Repair)
by dmh3355 9/7/2014 4:43:13 AM(UTC)
No heat, timer not advancing on autosense (Dryer Repair)
by fgaggia 9/5/2014 12:48:30 PM(UTC)
No Heat, Timer Does Not Advance (Dryer Repair)
by MRGETITFIXED 8/27/2014 8:36:01 AM(UTC)
No heat, so tested thermostats, now dryer won't even start (Dryer Repair)
by ccauthe 6/17/2014 4:26:40 AM(UTC)
No Heat, Tested parts for Continuity (Dryer Repair)
by crappyone 3/17/2014 9:42:46 AM(UTC)
GE Dryer No Heat, Tumbles, Open Door and Light Goes Out (Dryer Repair)
by essdiddy 1/11/2014 5:07:52 PM(UTC)
Dryer--No heat, continuity tests ok...what next? (Dryer Repair)
by davesharpe 1/5/2014 12:48:28 PM(UTC)
Dryer cyles, no heat, trips circuit breaker leg (Dryer Repair)
by kwillie 1/1/2014 3:07:19 PM(UTC)
no heat, thermostats good (Dryer Repair)
by deadchef 12/26/2013 5:51:08 PM(UTC)
