Power comes on, and both elements will heat up in the Broil setting, just not very hot. Like I can lick a finger and touch them. However when I turn the dial (yes it's that old) to bake, the warming light doesn't even come on at all. I tested the two elements and they have ohm readings around 20, and look in good shape still. Blew a fuse somewhere, bad temp sensor?
So what was solution. Did you just buy a new one?
Well figured out mine had a wire burn out on main selector. Reattached and is working fine again. Much to disappointment of my partner.
