tedshred
#1 Posted : Sunday, October 2, 2022 8:33:02 AM(UTC)
tedshred
Patient is a Jenn-Air JJW9630DDB double wall oven...
Upper oven is throwing "1d11" code on display for all modes (bake/convection/broil/clean).
Lower oven works fine.
About two years ago I had the same issue with the upper oven and replaced the oven sensor:
Whirlpool AP6011040 / WP74008369 Sensor, Oven
After replacement, the top oven worked fine for a while, but then reverted back to the "1d11" error.
What are the odds I got a dud replacement sensor?
I'm about to order another one to have on hand before I pull the oven out again.
I will check resistance on out both existing and new sensors, I figure I'll use boiling water to test them.
Does anyone have the range from ambient to 212F when I oHm them out on my meter?
Other than this recent issue, this is a great oven & I do not want to replace it
Any other insights?
Ted
