About 9-10 months ago we had a power outage/Surge and the main fuse on the control board blew. I replaced the board. The fuse has gone again, so I soldered in a new one. While moving the washer (while plugged in) the fuse blew again. I'm suspecting the lower wiring harness might have an issue, but don't see one at quick glance. (I've checked the continuity of the upper harness' as they're easy to get to) and they check OK. Is there anything else to check before just ordering a new lower harness??? TIA EDIT i should note, I tried changing the fuse in the old board as well, but when I tried it it keeps giving a F3 E2 fault (the temperature sensor tests good) Edited by user Sunday, August 14, 2022 9:43:03 AM(UTC)
| Reason: Not specified
