Was working fine then one day it started beeping about every 30-ish minutes with and without the door open. One day it just died, no lights no sound. I researched and didn't find much of anything on the internet. I replaced the main power board and it worked for 1 load and that was it. I replaced the door latch and it worked for 1 load and that was it.. Turned off breaker and turned back on. Worked for one load. Now even turning breaker off and on doesn't work. What is going on?
Joined: 6/19/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Alabama
Okay, so here's an update and maybe this will help... I turned the power off and went through the wiring and made sure the wires in the wire nuts were making good connection. I have been able to use it regularly now with no problems. However, it will make an ascending beep when closed every 25 minutes. If the door is not latched I get a descending beep at the same interval. There is no information on this issue that I have found. Any ideas?
