paulmars
#1 Posted : Thursday, May 26, 2022 2:21:47 PM(UTC)
paulmars
Following common resistance test procedures found on the web the magnetron and transformer are fine.
The big capacitor tests open. The diode attached to it reads mostly open in one direction, although sometimes my dvm will jump down to several meg ohms for a fraction of a second. Testing in other directions reads a constantly changing value of 5xxMeg to 8xxMeg.
Would these cause the fuse to blow?
Emerson mld mw8987b
Tks,
Paul
ThatGuy
#2 Posted : Friday, May 27, 2022 8:01:44 AM(UTC)
ThatGuy
Check the door switches for proper operation. MW ovens often use one switch as a monitor switch which will pop the fuse if there is a problem with the door.
paulmars
#3 Posted : Sunday, May 29, 2022 3:59:15 PM(UTC)
paulmars
switches tested ok. cap and diode test bad.
Unplugged transformer primary and microwave runs and fuse dont blow.
