Hello,
Without warning while baking : oven will reset, blinking clock, etc. Not good.
Considering the replacement of the oven control board but can't find R&M manual on particular model of oven to see if power supply is seperate from Control Board.
Thought process being, if DC conditions to Control Board are not good, then a new board will not solve a damn thing !
2011, year of manufacture, no error codes listed in care and feeding manual therefore oven incapable of SOME self diagnosis.
Please please advise when able.
Thanks, Todd
The presence of relays / surge suppression along the one side of circuit board makes me think the power supply is part of the Control Board.
Would need some help on where to find the correct parts numbers for the Sears Elite Model: C970-419431 Double Oven. I believe the manufacturer is Frigidaire.
The black outer glass on the door, which appear to be glued to two stainless steel panels shattered whilst I was trying to tighten a loose screw on the door handle. ITs for the upper door. Any help would be greatly appreciated
