max57
#1 Posted : Friday, October 1, 2021 9:05:00 AM(UTC)
max57
I'm having issues with the freezer of dual evap fridge,it does not get not cold enough, only 20F. ​
Fridge is working fine and temperatures range is 34 to 40F
The service diagnostic for this fridge did not show any errors.
All freezer thermistors and thermostat checked as PASSED by the fridge diagnostic.
Compressor Low/high when running are 0 to -3psi and 125 to 150psi.
When the compressor is off the low/high pressures equalizes to 30 PSI within 1 min and does drop , so I don't think there is a leak or a restriction in the capillary or in the freezer evap.
Frost pattern on the freezer evap coil looks normal.
Compressor amps range is ~1A -1.5A depending on speed.
is it possible I still have restriction or maybe low in Freon?
