cparke
#1 Posted : Tuesday, August 31, 2021 7:38:14 PM(UTC)
cparke
I have a Whirlpool WRS950SIAH00 side-by-side refrigerator/freezer. I have determined that there are broken wires in the wiring harness internal to the door, caused by the wires being slightly pulled each time the door open. This is causing the ice maker (which is mounted on the freezer door itself on this model) not to work, and now a ground fault is also happening (neutral line to ice maker is making intermittent contact with ground line) and that could get more serious if more wires (like hot) break also.
Looking for a clue here for where are the screws, clips, or snaps are to get inside the freezer door, as this thing seems pretty solid! Any clues or videos on how to fully open up a freezer door and get to the internal wiring and water tubes?
Edited by user Tuesday, August 31, 2021 8:11:23 PM(UTC)  | Reason: Not specified
