Bob McDonnell
#1 Posted : Wednesday, July 21, 2021 11:32:11 AM(UTC)
Guest
My 4 year old Frigidaire upright freezer stopped working. I unplugged it and checked to see if coils were frozen and they were not frozen over. I plugged it back in and the fan runs and I can hear the compressor running. the temperature in the freezer when back to 0 degrees. The next morning the freezer had shut off again. I replaced the defrost timer and it still runs for several hours and shuts off. It will run only after being unplugged and turned back on again. Any ideas?
ThatGuy
#2 Posted : Thursday, July 22, 2021 12:55:38 AM(UTC)
ThatGuy
Could be a bad cold control/thermostat. Need a model number to get a better idea of what we are dealing with.
Guest
#3 Posted : Thursday, July 22, 2021 3:52:39 AM(UTC)
Guest
It's a Frigidaire model # FFFU14F2QWJ. I put an OHM meter on the thermostat terminals and it registers when I rotate the dial from warm to cold. When I plug in the freezer it will run when I turn the thermostat to the coldest setting. The freezer temp went down to -20 after running non stop a couple of hours, then it shut and does not start again!
ThatGuy
#4 Posted : Monday, July 26, 2021 11:43:01 AM(UTC)
ThatGuy
When it should be running, but isn't, try tapping the thermostat knob lightly. If it comes on, your thermostat is sticking internally. Sorry about the delay. I don't get paid, just trying to help with something I know. Life gets in the way sometimes.
applesack37
#5 Posted : Tuesday, July 27, 2021 3:25:17 AM(UTC)
applesack37
Thanks Thatguy,
I replaced the thermostat, $10.45 on Amazon, and the freezer is working perfectly again!
