3 Pages<123
#21 Posted : Thursday, June 24, 2021 4:05:06 PM(UTC)
What is the complete model number of the microwave?
ThatGuy
#22 Posted : Saturday, June 26, 2021 2:21:32 AM(UTC)
ThatGuy
Hey Gene, If you are replying to the post by "guest" at Location: 99556, its some sort of bot that steals posts from other forums and posts them here. Very strange. Who makes this stuff? I can't figure out what the point is. I just ignore the posts that say ghost now.
Guest
#23 Posted : Tuesday, June 29, 2021 10:03:23 AM(UTC)
Guest
Originally Posted by: firemankurt Go to Quoted Post
My Kitchenaid oven light stayed on and oven light button would not turn it of. Instead panel beeps 3 times.
The solution was quite simple and required no dis-assembly (Although I found solution after dis-assembly.)
Problem is that Self cleaning oven lock is partially engaged.
To reset and fix:
1. Pull out on latching mechanism/hook under control panel.
2. Move to your right until interior light turns off. (simulates door closed)
3. Press Self clean button and let lock fully engage.
4. Press cancel to stop Self clean.
5. Close door
Hope this helps someone.
Guest
#24 Posted : Tuesday, June 29, 2021 10:06:00 AM(UTC)
Guest
Thank YOU So Much this definitely worked & saved us a lot of $ and time!!!
For others that may be looking what this problem also does is that it will
not engage your burners in the oven to light as it is sensing the door is open
Guest
#25 Posted : Monday, January 24, 2022 7:44:58 AM(UTC)
Guest
This worked for me too. Many thanks.
Glad I found your post p before I tried disassembling the door latch
Guest
#26 Posted : Friday, February 11, 2022 9:27:25 AM(UTC)
Guest
Cleaned the oven door for Kitchen Aid(kgss907sss01) and after replacing it the problem showed up. Went through the steps and......... PRESTO. Thank you.
Guest
#27 Posted : Monday, February 14, 2022 6:17:40 PM(UTC)
Guest
firemankurt has saved the day! Your suggestion worked great on our Bosch wall oven. Thanks!!!
M4SERRA
#28 Posted : Sunday, October 30, 2022 3:56:31 PM(UTC)
Guest
To reset and fix:
5. Close door
A tremendous help! You saved us from giving up and buying a new oven!
Thank you firemankurt!
Guest
#29 Posted : Friday, March 29, 2024 5:33:42 PM(UTC)
Guest
I had the same problem, we just bought whirlpool model # WGE745C0FS05 double oven on 3/2024. Both upper and lower oven lights were ON all the time. I was reading all the comments on the net, then someone said make sure both oven doors are snug tight and closed. I simply let doors close/slam with spring loaded mechanism on its own force. That fixed the problem. Looks like lock latches were not engaging properly, sending signal to oven light switches that door is still open. So it fixed the issue. Make sure oven doors are shut closed snugly. Hope this will help. C. M. Silver Spring, MD
Guest (10)
3 Pages<123
